NAME | Synopsis | Description | Options | Examples | Exit Status | See Also
list-jbi-binding-components
[--terse={true|false}][ --echo={true|false} ]
[ --interactive={true|false} ] [ --host host]
[--port port] [--secure| -s ] [ --user admin_user]
[--passwordfile filename] [--help]
[ --lifecyclestate shutdown|started|stopped]
[--libraryname shared_library_name]
[--assemblyname service assembly name]
[--target target]
The list-jbi-binding-components command lists all the binding components installed on the specified target. If no filters are specified, the command lists all the components installed on the target.
Indicates that any output data must be very concise, typically avoiding human-friendly sentences and favoring well-formatted data for consumption by a script. Default is false.
Setting to true will echo the command line statement on the standard output. Default is false.
If set to true (default), only the required password options are prompted.
The machine name where the domain administration server is running. The default value is localhost.
The HTTP/S port for administration. This is the port to which you should point your browser in order to manage the domain. For example, http://localhost:4848.
The default port number is 4848.
If set to true, uses SSL/TLS to communicate with the domain administration server.
The authorized domain administration server administrative username.
If you have authenticated to a domain using the asadmin login command, then you need not specify the --user option on subsequent operations to this particular domain.
The --passwordfile option specifies the name, including the full path, of a file containing the password entries in a specific format. The entry for the password must have the AS_ADMIN_ prefix followed by the password name in uppercase letters.
For example, to specify the domain administration server password, use an entry with the following format: AS_ADMIN_PASSWORD=password, where password is the actual administrator password. Other passwords that can be specified include AS_ADMIN_MAPPEDPASSWORD, AS_ADMIN_USERPASSWORD, and AS_ADMIN_ALIASPASSWORD.
All remote commands must specify the admin password to authenticate to the domain administration server, either through --passwordfile or asadmin login, or interactively on the command prompt. The asadmin login command can be used only to specify the admin password. For other passwords, that must be specified for remote commands, use the --passwordfile or enter them at the command prompt.
If you have authenticated to a domain using the asadmin login command, then you need not specify the admin password through the --passwordfile option on subsequent operations to this particular domain. However, this is applicable only to AS_ADMIN_PASSWORD option. You will still need to provide the other passwords, for example, AS_ADMIN_USERPASSWORD, as and when required by individual commands, such as update-file-user.
For security reasons, passwords specified as an environment variable will not be read by asadmin.
The default value for AS_ADMIN_MASTERPASSWORD is changeit.
Displays the help text for the command.
Helps list the JBI binding components based on its current state. For example, if you want to list only those binding components that are started, you can specify the option —lifecyclestate with the value as started. By default, all JBI binding components are listed, regardless of their states. Valid values for this option are:
shutdown, which lists all the JBI binding components that are currently shutdown on the specified target.
started, which lists all the JBI binding components that are in the 'started' state on the specified target.
stopped, which lists all the JBI binding components on the specified target that are not running.
Helps list the JBI binding components that currently use the specified library.
Helps list the JBI binding components that have a service unit deployed as part of the service assembly unit with the specified service assembly name.
Specifies the target for which you want to list the JBI binding components. Specify this option only if the binding components are deployed in a multiserver environment with a Domain Administration Server (DAS). If the binding components are not deployed in a multiserver environment with a DAS, this option is ignored. Valid values are:
server, which lists the binding components on the embedded DAS instance. This is the default value.
domain, which lists the binding components for the administrative domain itself. Specify domain only if you are using the cluster profile.
cluster_name, which lists the binding component for every server instance in the cluster
instance_name, which lists the binding components for the named unclustered server instance.
The following command lists the JBI binding components.
asadmin> list-jbi-binding-components --user admin2 --passwordfile passwords.txt --lifecyclestate started --libraryname library1 --target server1 Command list-jbi-binding-components executed successfully. |
install-jbi-component(1), delete-application-ref(1), delete-application-ref(1), delete-application-ref(1), delete-application-ref(1)
