NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
undeploy [--terse={true|false}][ --echo={true|false} ] [ --interactive={true|false} ] [ --host host] [--port port] [--secure| -s ] [ --user admin_user] [--passwordfile filename] [--help] [ --droptables =true|false] [--cascade=false] [ --target target] component_name
The undeploy command removes the specified deployed component.
This command is supported in remote mode only.
Indicates that any output data must be very concise, typically avoiding human-friendly sentences and favoring well-formatted data for consumption by a script. Default is false.
Setting to true will echo the command line statement on the standard output. Default is false.
If set to true (default), only the required password options are prompted.
The machine name where the domain administration server is running. The default value is localhost.
The HTTP/S port for administration. This is the port to which you should point your browser in order to manage the domain. For example, http://localhost:4848.
The default port number is 4848.
If set to true, uses SSL/TLS to communicate with the domain administration server.
The authorized domain administration server administrative username.
If you have authenticated to a domain using the asadmin login command, then you need not specify the --user option on subsequent operations to this particular domain.
The --passwordfile option specifies the name, including the full path, of a file containing the password entries in a specific format. The entry for the password must have the AS_ADMIN_ prefix followed by the password name in uppercase letters.
For example, to specify the domain administration server password, use an entry with the following format: AS_ADMIN_PASSWORD=password, where password is the actual administrator password. Other passwords that can be specified include AS_ADMIN_MAPPEDPASSWORD, AS_ADMIN_USERPASSWORD, and AS_ADMIN_ALIASPASSWORD.
All remote commands must specify the admin password to authenticate to the domain administration server, either through --passwordfile or asadmin login, or interactively on the command prompt. The asadmin login command can be used only to specify the admin password. For other passwords, that must be specified for remote commands, use the --passwordfile or enter them at the command prompt.
If you have authenticated to a domain using the asadmin login command, then you need not specify the admin password through the --passwordfile option on subsequent operations to this particular domain. However, this is applicable only to AS_ADMIN_PASSWORD option. You will still need to provide the other passwords, for example, AS_ADMIN_USERPASSWORD, as and when required by individual commands, such as update-file-user.
For security reasons, passwords specified as an environment variable will not be read by asadmin.
The default value for AS_ADMIN_MASTERPASSWORD is changeit.
Displays the help text for the command.
If set to true, tables created by application using CMP beans during deployment are dropped. The default is the corresponding entry in the cmp-resource element of the sun-ejb-jar.xml file. If not specified, it defaults to the entries specified in the deployment descriptors.
If set to true, it deletes all the connection pools and connector resources associated with the resource adapter being undeployed. If set to false, the undeploy fails if any pools and resources are still associated with the resource adapter. Then, either those pools and resources have to be deleted explicitly, or the option has to be set to true. If the option is set to false, and if there are no pools and resources still associated with the resource adapter, the resource adapter is undeployed. This option is applicable to connectors (resource adapters) and applications.
This option is valid only in domains that are configured to support clusters, such as domains that are created with the cluster profile or the enterprise profile.Specifies the target from which you are undeploying. Valid values are:
server, which undeploys the component from the default server instance server and is the default value
domain, which undeploys the component from the domain.
cluster_name, which undeploys the component from every server instance in the cluster.
instance_name, which undeploys the component from a particular sever instance.
Undeploy (uninstall) an enterprise application Cart.ear.
asadmin> undeploy --user admin --passwordfile password.txt Cart Command undeploy executed successfully. |
Undeploy a CMP bean named myejb and drop the corresponding database tables. In a production environment, database tables contain valuable information, so use the --droptables option with care.
asadmin> undeploy --user admin --passwordfile password.txt --droptables=true myejb Command undeploy executed successfully. |
Undeploy the connector module named jdbcra and perform a cascading delete to remove the associated resources and connection pools.
asadmin> undeploy --user admin --passwordfile password.txt --cascade=true jdbcra Command undeploy executed successfully. |
