NAME | Synopsis | Description | Options | Input WAR File | jaxrpc-ri.xml File | Namespace Mappings | Handlers | See Also
wsdeploy -o input_WAR_file options
Use the wsdeploy command to take a WAR file which does not have implementation specific server side tie classes to generate a deployable WAR file that can be deployed on the application server. wsdeploy internally runs wscompile with the -gen:server option. The wscompile command generates classes and a WSDL file which wsdeploy includes in the generated WAR file.
Generally, you don't have to run wsdeploy because the functions it performs are done automatically when you deploy a WAR with deploytool or asadmin.
location of the input class files.
keep temporary files.
use the specified directory as a temporary directory
required; location of the generated WAR file. This option is required.
generates code for the specified JAX-RPC SI version. Supported version are: 1.0.1, 1.0.3, 1.1, 1.1.1, and 1.1.2 (the default).
outputs messages about what the compiler is doing.
prints version information.
META-INF/MANIFEST.MF WEB-INF/classes/hello/HelloIF.class WEB-INF/classes/hello/HelloImpl.class WEB-INF/jaxrpc-ri.xml WEB-INF/web.xml
Where: HelloIF is the service endpoint interface, and HelloImpl is the class thatimplements the interface. The web.xml file is tghe deployment descriptor of a web component.
<xml version="1.0" encoding="UTF-8"?>
<webServices>
xmlns="http://java.sun.com/xml/ns/jax-rpc/ri/dd"
version="1.0"
targetNamespaceBase="http://com.test/wsdl"
typeNamespaceBase="http://com.test/types"
urlPatternBase="/ws">
<endpoint
name="MyHello"
displayName="HelloWorld Service"
description="A simple web service"
wsdl="/WEB-INF/<wsdlname>
interface="hello.HelloIF"
implementation="hello.HelloImpl"/>
<endpointMapping
endpointName="MyHello"
urlPattern="/hello"/>
</webServices>
The webServices() element must contain one or more endpoint() elements. The interface and implementation attriutes of endpoint() specify the service's interface and iimplementation class. The endpointMapping() element associates the service port with the part of the endpoint URL path that follows the urlPatternBase().
schemaType="ns1:SampleType" xmlns:ns1="http://echoservice.org/types"
When generating a Java type from a schema type, wscompile gets the classname from the local part of the schema type name. To specify the package name of the generated Java classes, you define a mapping between the schema type namespace and the package name. You define this mapping by adding a <namespaceMappingRegistry> element to the config.xml file. For example:
<service>
<namespaceMapping
namespace="http://echoservice.org/types"
packageName="echoservice.org.types"/>
</namespaceMappingRegistry>
</service>
You can also map namespaces in the opposite direction, from schema types to Java types. In this case, the generated schema types are taken from the package that the type comes from.
A handler accesses a SOAP message that represents an RPC request or response. A handler class must implement the javax.xml.rpc.handler interface. Because it accesses a SOAP message, a handler can manipulate the message with the APIs of the javax.xml.soap.package().
A handler chain is a list of handlers. You may specify one handler chain for the client and one for the server. On the client, you include the handlerChains() element in the jaxrpc-ri.xml file. On the server, you include this element in the config.xml file. Here is an example of the handlerChains() element in the config.xml:
<handlerChains>
<chain runAt="server"
roles=
"http://acme.org/auditing
"http://acme.org/morphing"
xmlns:ns1="http://foo/foo-1">
<handler className="acme.MyHandler"
headers ="ns1:foo ns1:bar"/>
<property
name="property" value="xyz"/>
</handler>
</chain>
</handlerChains>
For more information on handlers, see the SOAP message Handlers chapter of the JAX-PRC specifications.
