The BPEL Designer has a built-in BPEL code validation functionality that helps developers create well-formed, valid and standard-compliant code. The code is checked for errors and the user is notified if validation fails.
The Validator checks the BPEL process in accordance with the following criteria:
For conformance with the BPEL 2.0 schema.
See the Troubleshooting section of this guide for more information about using BPEL schemas different from the BPEL 2.0 specification.
For compliance with static analysis rules defined in the WS-BPEL 2.0 specification.
For broken references.
For constructs that are valid per the BPEL 2.0 specification but are not yet supported by the Sun BPEL Service Engine.
The BPEL Designer provides two types of validation:
Real-time validation
This type of validation is invoked automatically and does not require any explicit actions from the user. Only the current file is checked. The validation is performed in accordance with all the criteria mentioned above, except for validation for conformance with the BPEL 2.0 schema.
Explicit validation
This type of validation requires that the user explicitly invoke the validation process. All imported XSD and WSDL files are also checked. The validation is performed in accordance with all the criteria mentioned above.
To invoke explicit validation, do one of the following:
In the Source view, right-click the source and then select Validate XML (Alt-Shift-F9)
In the Design view, click the Validate XML button (Alt-Shift-F9) on the Editor toolbar.
The user is notified about validation errors or success in the Output window, in the Design view, and in the Navigator.
The results of validation appear in the Output window if validation has been invoked explicitly. If validation fails, the Output window contains errors and/or warnings:
If validation is successful, there are no warnings or errors in the Output window.
The Design view shows the results of both real-time and explicit validation in call-out windows on the diagram and the error stripe.
In the diagram, a red cross next to an element on the diagram means that the element has not passed validation and the output contains errors. A yellow triangle with an exclamation mark means that the element has not passed validation and the output contains warnings. If there are both errors and warnings, the Design view shows a red cross. If you click the cross or the triangle, a call-out window appears with a list of errors and/or warnings:
The call-out window includes messages related to validation in accordance with all the criteria listed above. Messages related to the real-time validation are constantly updated.
In the Design view, validation results are also shown by the error stripe, which is a strip to the right of the scroll bar that contains red marks if some elements have not passed validation. The error stripe represents the entire diagram, not just the portion that is currently displayed. You can immediately see if your BPEL process contains errors without having to scroll through the entire diagram. You can click a red mark to jump to the element that causes problems. If no errors are detected, the small square in the error stripe is green.
The Navigator window shows the results of both real-time and explicit validation by adding a red cross or a yellow triangle to the element's icon if validation has failed. For example, in the screenshot below, the AirlineReserved receive activity has not passed validation and the output contains errors.
