Process
WS-BPEL 2.0 process root element. The Process element is present
in the BPEL Designer diagram by default.
Supported Elements
extensions
import
partnerLinks
variables
correlationSets
faultHandlers
eventHandlers
Supported Attributes
Not Supported
queryLanguage (xpath only)
expressionLanguage (xpath only)
suppressJoinFailure
abstractProcess
exitOnStandardFault
Extensions
More Information
Variable
Supplies the mechanism used to hold messages that make up the
state of a business process.
Supported Elements
name
messageType
type
element
Extensions
More Information
Correlation
Tracks the multiple long-running exchanges of messages that
typically take place between a BPEL process and its partner services.
The correlation mechanism helps to route messages to appropriate process
instances.
Supported Elements
Extensions
More Information
EventHandlers
Invokes a specific action concurrently with a specified corresponding
event.
Supported Elements
Extensions
More Information
FaultHandlers
Defines the activities that are executed as a response to faults
resulting from invoked services.
Supported Elements
Extensions
More Information
Import
Used within a process to clearly express dependency upon external
XML Schema or WSDL definitions. The Process element can have any number
of Import elements as initial children, preceding any other child
element.
Supported Elements
namespace
location
importType
Extensions
More Information
Web Services
Invoke
Invokes a one-way or request-response operation on a portType
offered by a partner. It enables the business process to send messages
to partners. The operation is defined in the partner's WSDL file.
Supported Elements
correlations
toPart
fromPart
Not Supported
catch
catchAll
compensationHandler
partnerLink
portType
operation
inputVariable
outputVariable
Extensions
More Information
Receive
Allows the business process to do a blocking wait for a particular
message to arrive.
Supported Elements
partnerLink
portType
operation
Variable
createInstance
messageExchange
Extensions
More Information
Reply
Returns a message from the process to the same partner that
initiated the operation. The combination of Receive and Reply activities
creates a request-response operation.
Supported Elements
partnerLink
portType
operation
Variable
faultName
messageExchange
Extensions
More Information
PartnerLink
Identifies the parties that interact with your business process.
Each link is defined by a partner link type and a role name.
Supported Elements
name
partnerLinkType
myRole
partnerRole
Not Supported
Extensions
More Information
Basic Activities
Assign
Assigns values to variables. You use the Assign element to copy
data from one variable to another, construct and calculate the values
of expressions, and store new data in variables. Expressions are required
to perform simple computation or operate message selections, properties,
and literal constants to produce a new value for variables.
Supported Elements
from (name="variable" type="NCName")
from (name="part" type="NCName")
to (name="variable" type="NCName")
to (name="part" type="NCName")
validate
from (name="expressionLanguage" type="anyURI" —
xpath only)
from (name="property" type="QName")
from (name="partnerLink" type="NCName")
from (name="endpointReference" type="bpws:tRoles")
from (name="opaque" type="bpws:tBoolean")
to (name="queryLanguage" type="anyURI")
to (name="property" type="QName")
to (name="partnerLink" type="NCName")
Extensions
More Information
JavaScript
Acts like an Assign activity that enables you to use JavaScript
(E4X), rather than using XPath 1.0.
Supported Elements
Extensions
More Information
Validate
Validates the values of variables against their associated XML
and WSDL data definition. The element includes a Variables property
that lists the variables for the process, and allows you to specify
which variables to validate. When one or more variables prove invalid
against a corresponding XML definition, a standard fault, bpel:invalidVariables, is thrown.
Supported Elements
Extensions
More Information
Empty
Used as a placeholder within a process to catch and suppress
faults or to help synchronize actions within a flow activity that
are executed concurrently.
Supported Elements
Extensions
More Information
Wait
Waits for a specified time or until a deadline is reached.
Supported Elements
Extensions
More Information
Throw
Used to signal a specific internal fault, and can provide a
QName and information for that fault.
Supported Elements
Extensions
More Information
ReThrow
Used to rethrow a fault.
Supported Elements
Extensions
More Information
Exit
Terminates the execution of a business process instance.
Supported Elements
Extensions
More Information
Compensate
Invokes the compensation handler of a particular scope.
Supported Elements
Extensions
More Information
CompensateScope
Supported Elements
Extensions
More Information
Structured Activities
If
Supports conditional behavior of a business process instance.
The If activity consists of conditional branches defined by the If
and Else If elements, followed by an optional Else branch. The conditions
on If and Else If branches are evaluated in the order they appear.
During execution, the first branch whose condition holds true is taken
and provides the activity specified for the If activity. In other
words, if there are several Else If branches whose conditions hold
true, only the first of them will be executed.
Supported Elements
Extensions
More Information
While
Repeatedly execute one or more activities as long as specific
conditions are in place at the beginning of each iteration.
Supported Elements
Extensions
More Information
RepeatUntil
Repeatedly executes one or more activities as long as specific
conditions are in place after the execution of each iteration. This
element contains other elements that are repeated until the success
criteria you specify are met. If the condition you specify leads to
true, the activities listed will be executed once.
Supported Elements
Extensions
More Information
ForEach
Repeatedly execute its contained scope activity exactly N+1
times where N equals the Final Counter Value minus the Start Counter
Value.
Supported Elements
startCounterValue
finalCounterValue
completionCondition
Not Supported
Extensions
More Information
Pick
Blocks a process and waits until a specified events occurs.
After one of the specific event occurs, the activity associated with
this event is performed. The possible events are the arrival of a
message or a timer-based alarm. The selected activity is dependent
upon which event occurs first.
Supported Elements
Extensions
More Information
Flow
Defines a set of activities that will execute concurrently (in
parallel). This is a structured activity, containing other activities
separated into individual control paths or branches. You can embed
as many paths in the activity as you want, and they will all be executed
simultaneously.
Supported Elements
Not Supported
Extensions
More Information
Sequence
Used to nest a series of activities in a process. Activities
within a sequence execute in strict sequential order, completing when
the last activity within the nest has finished.
Supported Elements
Extensions
More Information
Scope
Essentially, this activity is a collection of child activities
that can have their own Variables, Fault and Event Handlers, and correlation
sets. The Scope activity provides the behavior context for the child
elements.
Supported Elements
variables
faultHandlers
eventHandlers
Not Supported
partnerLinks
correlationSets
compensationHandler
terminationHandler
Not Supported
isolated
exitOnStandardFault
Extensions
More Information
Other Activities
OnMessage
Supported Elements
Extensions
More Information
OnMsgCommon
Supported Elements
partnerLink
portType
operation
messageExchange
Extensions
More Information
OnAlarmPick
Specifies an event that is triggered when a given duration variable
is exceeded.
Supported Elements
Extensions
More Information
CompletionCondition
Supported Elements
Extensions
More Information
Catch
Used to intercept a specifically defined type of fault.
Supported Elements
faultName
faultVariable
faultMessageType
faultElement
Extensions
More Information
OnEvent
Indicates that a specified event is triggered when a message
arrives.
Supported Elements
Extensions
More Information
Activity
Supported Elements
Not Supported
Not Supported
Extensions
More Information
property
Defines a unique name and associates it with an XML Schema simple
type.
Supported Elements
Extensions
More Information
propertyAlias
Defines a globally named property as an alias.
Supported Elements
propertyName
messageType
part
Not Supported
Extensions
More Information
PartnerLinkType
Expresses the dependences between services by defining each
service's role.
Supported Elements
Extensions
More Information
Role
Specifies one WSDL portType.
Supported Elements
Extensions
More Information
CorrelationWithPattern
Supported Elements
Extensions
More Information
