Master Index Standardization Engine Reference
How the Master Index Standardization Engine Works
The Master Index Standardization Engine uses two frameworks to define standardization logic. One framework is based on a finite state machine (FSM) model and the other is based on rules programmed in Java. In the current implementation, the person names and telephone numbers are processed using the FSM framework, and addresses and business names are processed using the rules-based framework. The Master Index Standardization Engine includes several sets of files that define standardization logic for all supported data types. For person data and addresses, one set of standardization files is provided for the following national variants: Australia, France, Great Britain, and the United States. You can customize these files to adapt the standardization and matching logic to your specific needs or you can create new data types or variants for even more customized processing. With pluggable standardization sets, you can define custom standardization processing for most types of data.
The following topics provide information about the Master Index Standardization Engine, the standardization frameworks, and data is standardized:
Master Index Standardization Engine Data Types and Variants
A data type is the primary kind of data you are processing, such as person names, addresses, business names, automotive parts, and so on. A variant is a subset of a data type that is designed to standardize a specific kind of data. For example, for addresses and names, the variants typically define rules for the different countries in which the data originates. For automotive parts, the variants might be different manufacturers. Each data type and variant uses its own configuration files to define how fields in incoming records are parsed, standardized, and classified for processing. Data types are sometimes referred to as standardization types.
In the default implementation with a master index application, the engine supports data standardization on the following types of data:
In the default configuration, the standardization engine expects street address and business names to be in free-form text fields that need to be parsed prior to normalization and phonetic encoding. Person and phone information can also be contained in free-form text fields, but theses types of information can also be processed if the data is already parsed into its individual components. Each data type requires specific customization to mefa.xml in the master index project. This can be done by modifying the file directly or by using the Master Index Configuration Editor.
Master Index Standardization Engine Standardization Components
The Master Index Standardization Engine breaks down fields into various components during the parsing process. This is known an tokenization. For example, it breaks addresses into floor number, street number, street name, street direction, and so on. Some of these components are similar and might be stored in the same output field. In the default configuration for a master index application, for example, when the standardization engine finds a house number, rural route number, or PO box number, the value is stored in the HouseNumber database field. You can customize this as needed, as long as any field you specify to store a component is also included in the object structure defined for the master index application.
The standardization engine uses tokens to determine how to process fields that are defined for normalization or parsing into their individual standardization components. For FSM-based data types, the tokens are defined as output symbols in the process definition files and are referenced in the standardization structures in the Master Index Configuration Editor and in mefa.xml. The tokens determine how each field is normalized or how a free-form text field is parsed and normalized. For rules-based data types, the tokens are defined internally in the Java code. The tokens for business names specify which business type key file to use to normalize a specific standardization component. The tokens for addresses determine which database fields store each standardization component and how each component is standardized.
Finite State Machine Framework
A finite state machine (FSM) is composed of one or more states and the transitions between those states. The Master Index Standardization Engine FSM framework is designed to be highly configurable and can be easily extended with no Java coding. The following topics describe the FSM framework and the configuration files that define FSM–based standardization.
About the Finite State Machine Framework
In an FSM framework, the standardization process is defined as one or more states. In a state, only the input symbols defined for that state are recognized. When one of those symbols is recognized, the following action or transition is based on configurable processing rules. For example, when an input symbol is recognized, it might be preprocessed by removing punctuation, matched against a list of tokens, and then postprocessed by normalizing the input value. Once this has been completed for all input symbols, the standardization engine determines which token is the most likely match.
FSM-based processing includes the following steps:
Using the person data type, for example, first names such as “Bill” and “Will” are normalized to “William”, which is then converted to its phonetic equivalent. Standardization logic is defined in the standardization engine configuration files and in the Master Index Configuration Editor or mefa.xml in a master index project.
FSM-Based Configuration
The FSM-based standardization configuration files are stored in the master index project and appear in the Standardization Engine node of the project. These files are separated into groups based on the primary data types being processed. Data type groups have further subsets of configuration files based on the variants for each data type. FSM-based data types and variants, such as PersonName and PhoneNumber, include the following configuration file types.
Rules-Based Framework
In the rules-based framework, the standardization process is define in the underlying Java code. You can configure several aspects of the standardization process, such as the detectable patterns for each data type, how values are normalized, and how the input string is cleansed and parsed. You can define custom rules-based data types and variants by creating custom Java packages that define processing.
About the Rules-Based Framework
In the rules-based framework, individual field components are recognized by the patterns defined for each data type and by information provided in configurable files about how to preprocess, match, and postprocess each field components. The rules-based framework processes data in the following stages.
Using the street address data type, for example, street addresses are parsed into their component parts, such as house numbers, street names, and so on. Certain fields are normalized, such as street name, street type, and street directions. The street name is then phonetically converted. Standardization logic is defined in the standardization engine configuration files and in the Master Index Configuration Editor or mefa.xml in a master index project.
Rules-Based Configuration
The rules-based standardization configuration files are stored in the master index project and appear as nodes in the Standardization Engine node of the project. These files are separated into groups based on the primary data types and variants being processed. Rules-based data types and variants, such as the default Address and Business Name types, use the following configuration file types.
