Sun Master Index Configuration Reference
Update Manager Policies
The Update Manager policies specify custom Java classes that provide additional processing logic for each type of update transaction. By default, this additional processing is not defined in a standard master index application. You can define custom update policies by creating the custom classes in the Source Packages node of the EJB project associated with the main master index project. NetBeans also provides the ability to build and compile the custom Java code, and Sun Master Index automatically incorporates the classes when you generate the application. The Java classes defining the update policies are specified for the master index application in the UpdateManagerConfig element of update.xml.
Update Manager Update Policies
There are seven types of update policies defined in the Update Manager.
Update Manager Update Policy Flag
The update policy section includes a flag that can prevent the update policies from being carried out if no changes were made to the existing record. When set to “true”, the SkipUpdateIfNoChange flag prevents the update policies from being performed when no changes are made to an existing record. Setting the flag to true helps increase performance when processing a large number of updates.
