Sun Master Index Configuration Reference
Simple Field Name Notation
In midm.xml, simple field names are used to specify the location of a field that appears on the MIDM. These are used in the GUI configuration section of the file. Simple field names define a specific field and are not used to define a list of fields. They include only the field name and the name of the object that contains the field. Simple field names allow you to define fields within the context of an object.
The following topics describe and illustrate how to form simple field notations:
Simple Field Notation Syntax
The syntax of a simple field name is:
object.field_name
where object refers to the name of the object that contains the field being defined and field_name is the full name of the field.
Simple Field Notation Example
The following sample illustrates an object structure that could be defined in object.xml. The object contains a Person parent object, and Address and Phone child objects.
Person
   FirstName
   LastName
   DateOfBirth
   Gender
   -Address
      AddressType
      StreetAddress
      Street
      City
      State
      PostalCode
   -Phone
      PhoneType
      PhoneNumber
The following simple field names are valid for the sample structure above.
