Sun Master Index Configuration Reference
ePath Notation
In update.xml, an element path, called an ePath, is used to specify the location of a field or list of fields. ePaths are also used in the StandardizationConfig element of mefa.xml. An ePath is a sequence of nested nodes in an enterprise record where the most nested element is a data field or a list of data fields. ePaths allow you to retrieve and transform values that are located in the object tree.
ePath strings can be of four basic types:
A context node is specified when evaluating each ePath expression. The context is considered as the root node of the structure for evaluation.
These topics describe and illustrate how to form ePath strings:
ePath Syntax
The syntax of an ePath consists of three components: nodes, qualifiers, and fields, as shown below.
node{.node{”[”qualifier’]’}+}+.field
ePath Notation Example
The following sample illustrates an object structure containing a system object from Site A with a local ID of 111. The object contains a first name, last name, and three addresses. Following the sample, there are several ePath examples that refer to various elements of this object structure along with a description of the data in the sample object structure referred by each ePath.
Enterprise
   SystemObject - A 111
      Person
         FirstName
         LastName
         -Address
            AddressType = Home
            Street = 800 Royal Oaks Dr.
            City = Monrovia
            State = CA
            PostalCode = 91016
         -Address
            AddressType = Office
            Street = 181 2nd Ave..
            City = Monrovia
            State = CA
            PostalCode = 91016
         -Address
            AddressType = Billing
            Street = 100 Grand Avenue
            City = El Segundo
            State = CA
            PostalCode = 90245
