Sun Master Index Configuration Reference
Features of Sun Master Index
Sun Master Index provides features and functions to allow you to create and configure master index application for any type of data. The primary function of Sun Master Index is to automate the creation of a highly configurable master index application. A wizard guides you through the initial setup steps, and the Master Index Configuration Editor allows you to further customize the configuration of the master index application. The components you need to implement a master index application are automatically generated.
Sun Master Index provides the following features:
