The Matching Service, configured in mefa.xml, contains the matching and standardization engines used in the match process, as well as the phonetic encoders used for phonetically encoding data. You can configure the match and standardization engines for the master index application in mefa.xml, and also specify special standardization, matching, and weighting logic used by the engines. This file also defines the strategy for identifying unique records and finding the best matches in the master index database. For optimization, the Match Field components are configurable, allowing you to choose the strategy that best fits your requirements or to implement your own custom components.
The following topics describe the components of the Matching Service and the structure of mefa.xml:
The Matching Service is configured by mefa.xml, which defines the configurable properties for standardizing data and matching records. These processes are highly configurable for the master index application, allowing you to design and develop the match strategy that best suits your processing requirements.
The following components make up the Matching Service:
Standardization of incoming data applies three functions to the data processed by the master index application: reformatting (or parsing), normalization, and phonetic encoding. These functions help prepare data for matching and searching. Some fields might require all three steps, some just normalization and phonetic conversion, and other data might only need phonetic encoding. You can specify which fields require any of these steps in the standardization configuration section of mefa.xml. In addition, you can specify the nationality of the data being standardized by the Master Index Standardization Engine.
If incoming records contain data that is not formatted properly, it must be reformatted before it can be normalized. One good example of this is free-form text address fields. If you are matching or searching on street addresses that are contained in one or more free-form text fields (that is, the street address is contained in one field, apartment number in another, and so on), that field must be parsed into its individual components (house number, street name, street type, and so on) before the data can be normalized.
When you normalize data, the data is converted into a standard form. A common use for normalization is to convert nicknames into their standard names, such as converting “Rich” to “Richard” or “Meg” to “Margaret”. Another example is normalizing street address components. For example, “Dr.” or “Drv” in a street address might be normalized to “Drive”. Normalized values are obtained from lookup tables.
Once data has gone through any necessary reformatting and normalization, it can be phonetically encoded. Phonetic values are generally used in blocking queries in order to obtain all possible matches to an incoming record. They are also used to perform searches from the MIDM that allow for misspellings and typographic errors. Typically, first names use Soundex encoding and last names and street names use NYSIIS encoding.
The MatchingConfig section of mefa.xml allows you to define the data fields that are sent to the match engine (called the match string). Probabilistic weighting is performed only against the fields you specify as the match columns. You can specify any field in the object structure as a match column as long as the is configured to use all fields specified. You must specify at least one match field. You can further configure the match string by removing known default or invalid values from the matching process. For more information, see SBR, Matching, and Blocking Filter Configuration.
The configuration of this section of mefa.xml is specific to the you are using and the types of fields on which you are matching. For more information about how the matching should be configured for the Master Index Match Engine, see Master Index Match Engine Reference.
The MEFAConfig section specifies the Java classes to be used by components of the Matching Service, including the match and standardization engines, block picker, and pass controller. The match and standardization engines control the processes of standardizing data and generating matching probability weights between records. The block picker and pass controller define how the blocking query is executed during the match process.
Sun Master Index provides the ability to use the standardization and match engines that best suit your indexing requirements. You can configure the master index application to use the Master Index Match Engine and the Master Index Standardization Engine, or you can configure the index to use a customized engine of your choice.
These engines perform two functions:
Standardize data to a common format
Calculate the likelihood that two objects match
The engines are called during match processing, when the master index application retrieves the best matches during a weighted search from the MIDM or when the master index application checks for duplicate records during an insert or update from the MIDM or an external system.
By default, the matching process is executed in multiple stages. Each configured block that defines query criteria is executed and evaluated separately (each query block execution and evaluation is referred to as a match pass). After a block is evaluated, the pass controller determines whether the results found are sufficient or matching should continue by performing another match pass.
The block picker chooses the block definition to use for each match pass. Block definitions define the criteria for each query that checks the database for a subset of the records to be used for matching. The block picker has access to the match results from previous match passes, as well as lists of applicable block definitions that have been executed and of those that have not been executed.
Sun Master Index provides extensible phonetic encoding capabilities, which are typically used to retrieve records with similar field values from the database for matching. By default, several phonetic encoders are defined to be used in the master index application. Typically, Soundex is used to encode first names (or SoundexFR for first names in the France national domain) and NYSIIS to encode last names. When using the Master Index Standardization Engine, you can specify different types of phonetic encoders, such as Metaphone, Double Metaphone, and Refined Soundex. When you specify the fields in the standardization configuration to be phonetically encoded, you can select one of the encoders defined in the phonetic encoders section.
The following steps illustrate one possible processing sequence that occurs when data is received from an external system and processed by the master index application.
A record is received from an external system.
The local ID does not yet exist in the master index application; initiate the standardization and matching process.
Standardize the record to a common format.
Standardize free-form text.
Normalize fields that need to be converted to a common format.
Phonetically encode fields that are commonly misspelled or spelled in different ways.
Match the record against entries in the database.
Use the selected blocking query (specified in master.xml) to retrieve a block of records that might match the new record.
Build and execute the query according to the input record.
Calculate match scores comparing the incoming record against existing records (this is done by the match engine).
Determine whether to repeat the matching process with another block of records, based on the MEFAConfig element in mefa.xml.
Return match scores for further processing.
Determine whether to add the system record to an existing EUID record or to insert the system record as a new EUID record (based on the parameters defined in the DecisionMaker element of master.xml).
The properties for the match and standardization process are defined in mefa.xml. Some of the information entered into the default configuration file is taken from the wizard, but the file might require additional customization in order to meet your data processing needs.
The following topics provide information about working with the mefa.xml:
You can modify mefa.xml at any time, but modifying the file is not recommended once you move to production because this file defines how records are processed and data integrity is maintained. You must regenerate the application and redeploy the project after making any changes to this file. Modifying this file once you are in production might cause weighting and standardization to be handled differently, causing unexpected match weight results.
Most of the components configured by this file can be modified using the Configuration Editor. The editor provides a graphical interface that simplifies defining normalization, standardization, matching, and phonetic encoding. It also maintains referential integrity between files in cases where standardization, normalization, or phonetic encoding requires additional fields to be added to the object structure. The possible modifications to this file are restricted by the schema definition, so be sure to validate the file after making any changes.
This topic describes the structure of the XML file, general requirements, and constraints. It also provides a sample implementation.
Table 11 lists each element in mefa.xml and provides a description of each element along with any requirements or constraints for each element.
Table 11 mefa.xml File Structure|
Element/Attribute |
Description |
The configuration information for fields to be standardized. It consists of several structures that define standardization rules for a set of fields. The StandardizationConfig attributes define the module name and Java class, and their default values should not be changed. |
A standardization structure that defines configuration rules, including normalization, parsing, and phonetic encoding. Each standardization structure contains three primary elements: structures-to-normalize, free-form-texts-to-standardize, and phoneticize-fields. These elements are all required, however any of them can be empty |
The name of the object containing the fields defined for standardization. Specifying the parent object allows you to specify any field in any object for standardization. You can also create multiple standardization structures and specify a different object for each structure. |
The configuration information for fields that require normalization (but not parsing or reformatting) before being processed by the standardization engine. |
The national domain, source fields, and target fields for one normalization unit. You can define multiple group elements. |
The type of standardization to perform on the source fields. This is specific to the type of data being processed and the standardization engine being used. For more information about Master Index Standardization Engine types, see Master Index Standardization Engine Reference. |
The Java class used by the Master Index Standardization Engine to determine the nationality of the data being processed. If no selector is specified, the default is US. Possible values for the Master Index Standardization Engine include the following:
The ePath to an identifying field in the object structure that indicates which of the defined local-codes definitions to use. If no field is specified, the standardization engine defaults to the United States domain. This field must be contained in the object that contains the fields defined for normalization in this structure. |
A list of local codes that define how the standardization engine determines which national domain to use. |
A list of value and locale pairs that indicate the national domain to use based on the value of the identifying field in an incoming message (specified by the local-field-name). |
A value that, when contained in the identifying field, indicates that the standardization engine will use the corresponding locale element to determine which national domain to use to standardize the data. To specify a default domain, enter “Default” in this element. |
A domain code indicating which national domain to use to standardize data when the identifying field value in a transaction matches the corresponding value element. The supported locale codes for the Master Index Standardization Engine include the following:
A list of source fields to be normalized. |
The configuration information for one field in the list of source fields to be normalized. |
The ePath of the source field to normalize in the system object (for example, Person.FirstName). |
An identification code that identifies the field to normalize to the standardization engine. This ID is specific to the standardization engine in use and must correspond to a field ID defined by that engine. For more information, see Master Index Standardization Engine Reference. |
A list of destination fields to hold the normalized data. |
The configuration information for one field in the list of destination fields. |
An identification code that identifies the normalized field to the standardization engine. This is specific to the standardization engine in use and must correspond to a field ID defined by that engine. For more information, see Master Index Standardization Engine Reference. |
The ePath of the target field in which the normalized value is saved in the system object (for example, Person.Alias[*].StdLastName). |
The configuration information for fields that require parsing or reformatting and, optionally, normalization, before being processed by the standardization engine. |
The configuration information for the national domain and the source and target fields for one standardization unit. You can define multiple group elements. |
The type of standardization to perform on the source fields. This is specific to the standardization engine being used and the type of data being processed. For more information, see Master Index Standardization Engine Reference. |
The Java class used by the Master Index Standardization Engine to determine the nationality of the data being processed. Possible values are listed below. If no selector is specified, the default is US.
The ePath to an identifying field in the object structure that indicates which of the defined local-codes definitions to use. If this element is not defined, the standardization engine defaults to the United States domain. This field must be contained in the object that contains the fields defined for standardization in this structure. |
A domain code indicating which national domain to use to standardize data when the identifying field value in a transaction matches the corresponding value element. Supported locale codes for the Master Index Standardization Engine are listed below.
A list of fields to be standardized. |
A field to be standardized. If you define more than one source field in the same standardization unit, the fields are concatenated during standardization with a pipe (|) between lines (for the Master Index Standardization Engine). |
A list of fields in which the standardized data from the source fields is stored. |
The configuration information for one destination field in which standardized data from the source field will be stored. One source field will likely have several destination fields. |
An abbreviation that identifies the destination field to the standardization engine. This must correspond to a field ID defined by the standardization engine being used. For more information, see Master Index Standardization Engine Reference. |
The ePath of the destination field in the object where the standardized value will be saved (for example, Person.Address[*].StreetName). |
A list of fields to be phonetically encoded. |
The configuration information for each field to be phonetically encoded, including the encoder to use. |
The ePath of the source field in the system object from which the value to phonetically encode will be retrieved (for example, Person.Address[*].StreetName). Note – This can refer to the original field or to a standardized or normalized field. |
The ePath of the field in which the phonetically encoded value will be saved in the system object. |
A field ID to identify the field to the phonetic encoder. This is not currently used with the Master Index Standardization Engine. |
The phonetic encoder to use for this field. This must correspond to the encoding-type configured for the desired encoder in the PhoneticEncodersConfig element. |
The configuration information for the match string (that is, the fields that are included in the data string sent to the match engine and against which weighting is performed). The attributes of the MatchingConfig element define the module name and Java class, and their default values should not be changed. |
The configuration and field definitions for the match string. |
The name of the object containing the fields in the match string. If you specify the parent object, you can specify fields from the parent and any child object in the match string. |
A list of fields in the match string. This element contains multiple match-column elements. |
The configuration information for one field in the match string. You will use multiple match-column elements. |
The fully qualified field name that defines the location of each field on which to match (for example, Enterprise.SystemSBR.Person.Address.City). |
The type of matching performed on the specified field. This is an ID that is specific to the match engine and identifies the field to the match engine. This value must correspond to a match type defined for the match engine. |
An integer specifying the order in which the field appears in the match string. This element is optional. If no order is specified, matching is performed in the order in which the fields are listed. |
The configuration information for the components of the matching service. The MEFAConfig attributes (module-name and parser-class) define the module name and Java class, and their default values should not be changed. You should only change the names of the component classes in this section if you created a corresponding custom component. |
The configuration information for the Java class that chooses which block of criteria defined for the blocking query to use for each match pass. |
The name of the block picker Java class. |
The configuration information for the Java class that determines whether the blocking query should continue performing match passes after each match pass is complete. |
The name of the pass controller Java class. |
The configuration information for the standardization engine to use. |
The name of the standardizer API Java class. |
The configuration information for the Java class that provides configuration information to the standardization engine. |
The name of the standardizer configuration Java class. |
The configuration information for the match engine to use. |
The name of the match engine API Java class. |
The configuration information for the Java class that provides configuration information to the match engine. |
The name of the match engine configuration Java class. |
The configuration information for the phonetic encoders used by the master index application. The attributes (module-name and parser-class) define the module name and Java class. The default values should not be changed. |
A list of phonetic encoders used by the standardization engine. |
The name of the phonetic encoder, such as NYSIIS, Soundex, or Metaphone. |
The fully qualified name of the Java class that determines the behavior of the phonetic encoder. The following default classes are defined for the Master Index Match Engine.
Below is a short sample of mefa.xml based on a master index application processing person data. This sample covers the basic elements of mefa.xml, but a production environment would contain several more fields to standardize as well as several additional match string fields.
<StandardizationConfig module-name="Standardization" parser-class=
"com.sun.mdm.index.configurator.impl.standardization.StandardizationConfiguration">
<standardize-system-object>
<system-object-name>Person</system-object-name>
<structures-to-normalize>
<group standardization-type="PersonName" domain-selector=
”com.sun.mdm.index.matching.impl.SingleDomainSelectorUS">
<unnormalized-source-fields>
<source-mapping>
<unnormalized-source-field-name>
Person.Alias[*].FirstName
</unnormalized-source-field-name>
<standardized-object-field-id>FirstName
</standardized-object-field-id>
</source-mapping>
<source-mapping>
Person.Alias[*].LastName
<standardized-object-field-id>LastName
</source-mapping>
</unnormalized-source-fields>
<normalization-targets>
<target-mapping>
<standardized-target-field-name>
Person.Alias[*].StdFirstName
</standardized-target-field-name>
</target-mapping>
<target-mapping>
</target-mapping>
</normalization-targets>
</group>
"com.sun.mdm.index.matching.impl.SingleDomainSelectorUS”>
<source-mapping>
<unnormalized-source-field-name>Person.FirstName
</source-mapping>
<source-mapping>
<unnormalized-source-field-name>Person.LastName
</source-mapping>
<target-mapping>
<standardized-target-field-name>Person.StdFirstName
</target-mapping>
<target-mapping>
<standardized-target-field-name>Person.StdLastName
</target-mapping>
</group>
</structures-to-normalize>
<free-form-texts-to-standardize>
<group standardization-type="Address" domain-selector=
"com.sun.mdm.index.matching.impl.MultiDomainSelector">
<locale-field-name>Person.Country</locale-field-name>
<locale-maps>
<locale-codes>
<value>Default</value>
<locale>US</locale>
</locale-codes>
</locale-maps>
<unstandardized-source-fields>
<unstandardized-source-field-name>
Person.Address[*].AddressLine1
</unstandardized-source-field-name>
Person.Address[*].AddressLine2
</unstandardized-source-fields>
<standardization-targets>
<target-mapping>
<standardized-object-field-id>HouseNumber
Person.Address[*].HouseNumber
</target-mapping>
<target-mapping>
<standardized-object-field-id>MatchStreetName
</target-mapping>
<target-mapping>
StreetNamePrefDirection
Person.Address[*].StreetDir
</target-mapping>
<target-mapping>
<standardized-object-field-id>StreetNameSufType
Person.Address[*].StreetType
</target-mapping>
</standardization-targets>
</group>
</free-form-texts-to-standardize>
<phoneticize-fields>
<phoneticize-field>
<unphoneticized-source-field-name>Person.FirstName_Std
</unphoneticized-source-field-name>
<phoneticized-target-field-name>Person.FirstName_Phon
</phoneticized-target-field-name>
<encoding-type>Soundex</encoding-type>
</phoneticize-field>
<phoneticize-field>
<unphoneticized-source-field-name>Person.LastName_Std
<phoneticized-target-field-name>Person.LastName_Phon
<encoding-type>NYSIIS</encoding-type>
<phoneticize-field>
Person.Address[*].StreetNamePhoneticCode
</phoneticize-fields>
</standardize-system-object>
</StandardizationConfig>
<MatchingConfig module-name="Matching" parser-class=
"com.sun.mdm.index.configurator.impl.matching.MatchingConfiguration">
<match-system-object>
<object-name>Person</object-name>
<match-columns>
<match-column>
<column-name>Enterprise.SystemSBR.Person.StdFirstName
</column-name>
<match-type>FirstName</match-type>
</match-column>
<match-column>
<column-name>Enterprise.SystemSBR.Person.StdLastName
</column-name>
<match-type>LastName</match-type>
</match-column>
<match-column>
<column-name>Enterprise.SystemSBR.Person.DOB</column-name>
<match-type>DOB</match-type>
</match-column>
</match-columns>
</match-system-object>
</MatchingConfig>
<MEFAConfig module-name="MEFA" parser-class=
"com.sun.mdm.index.configurator.impl.MEFAConfiguration">
<block-picker>
<class-name>com.sun.mdm.index.matching.impl.PickAllBlocksAtOnce
</class-name>
</block-picker>
<pass-controller>
<class-name>com.sun.mdm.index.matching.impl.PassAllBlocks
</class-name>
</pass-controller>
<class-name>
com.sun.mdm.index.matching.adapter.SbmeStandardizerAdapter
</class-name>
</standardizer-api>
<standardizer-config>
<class-name>
com.sun.mdm.index.matching.adapter.SbmeStandardizerAdapterConfig
</class-name>
</standardizer-config>
<matcher-api>
<class-name>com.sun.mdm.index.matching.adapter.SbmeMatcherAdapter
</class-name>
</matcher-api>
<matcher-config>
<class-name>
com.sun.mdm.index.matching.adapter.SbmeMatcherAdapterConfig
</class-name>
</matcher-config>
</MEFAConfig>
<PhoneticEncodersConfig module-name="PhoneticEncoders" parser-class=
"com.sun.mdm.index.configurator.impl.PhoneticEncodersConfig">
<encoder>
<encoder-implementation-class>
com.sun.mdm.index.phonetic.impl.Nysiis
</encoder-implementation-class>
</encoder>
<encoder>
com.sun.mdm.index.phonetic.impl.Soundex
</encoder>
</PhoneticEncodersConfig>
