Sun Master Index Configuration Reference
Relationship Properties
In midm.xml, relationships define the hierarchy of the object types listed on the MIDM. By specifying relationships, you define parent and child nodes. The parent and child nodes you specify in the relationships element must also be defined in the node elements of the file. You can specify one parent object; the remaining objects must be child objects to the parent you define. The relationships section is dependent on the relationships section in object.xml, and should only be changed if corresponding changes are made to object.xml.
