Sun Master Index Configuration Reference
The query.xml File Structure
This topic describes the structure of the XML file, including general requirements and constraints, and provides a sample implementation.
query.xml File Description
Table 2 lists each element in query.xml and provides a description of each element along with any requirements or constraints for each element.
Table 2 query.xml File Structure
Element/Attribute
Description
QueryBuilderConfig
The configuration class for the query builders. This should not be modified.
query-builder
A list of query definitions. This element defines each query and the attributes of each query.
query-builder/name
A unique ID for the element. This element is used to identify the Query Builder and is referenced from midm.xml when specifying the query to use on a search page. It is also referenced from mefa.xml when specifying the query to use for matching. No spaces are allowed in this attribute.
query-builder/class
The fully qualified name of the query class. Two default Query Builder classes are provided.
  • com.sun.mdm.index.querybuilder.BasicQueryBuilder – Builds dynamic queries using all the available input fields. When configured to use normalized and phonetic data, this query performs phonetic searches; when configured not to use normalized and phonetic data, this query is used for exact alphanumeric searches.
  • com.sun.mdm.index.querybuilder.BlockerQueryBuilder – Builds queries using the criteria defined in the block definitions defined for the query. When a blocking query is performed, the application searches only on the blocks for which the query has complete data.
query-builder/parser-class
The fully qualified name of the class that parses the config elements for each query. This should not be modified for the default queries.
query-builder/standardize
An indicator of whether the query criteria is standardized before being passed to the query. Specify true if any fields are standardized for the query; specify false if no fields are standardized for the query.
query-builder/phoneticize
An indicator of whether the query criteria is phonetically encoded before being passed to the query. Specify true if any fields are phonetically encoded for the query specify; false if no fields are phonetically encoded for the query.
config
The configuration information for a query. Each query-builder element contains one config element.
option
One query parameter, specified by key and value attributes, as described below. This is only used by basic queries; blocking queries do not use this element.
option/key
A parameter for the query option. For the default basic query, only the UseWildCard key is available.
option/value
The value of the key specified by the corresponding key attribute. For the default option, UseWildCard, specify true to allow wildcard characters for that query type; otherwise specify false. When wildcard characters are enabled, you can enter a percent sign (%) to indicate multiple unknown characters.
block-definition
A list of database hints and defined query criteria blocks, which are identified by unique ID numbers.
block-definition/number
An attribute of the block-definition element that specifies the unique ID number of each query block. Each block defined for the blocking query must be identified by a unique ID.
hint
A hint to add to the query to help optimize query execution. Hints are especially useful when a blocking query uses only child object fields; the hint can specify to scan the child object table first. This element is optional. For SQL Server, only OPTION hints are supported.
block-rule
A list of fields to be included in each query block, including indicators of whether a range is to be used and, if so, what type of range search to perform.
type of search
An indicator of the type of search to perform on the field defined in the following elements. Each type of search element defines one field in a block-rule element; that is, one field in a query block. This element includes a field element, a source or constant element, and, for range searches only, a default element that defines lower and upper bounds.
Specify one of the following types.
  • equals - Performs an exact search against either the criteria or the value defined for the constant element.
  • not-equals - Searches for values that do not equal either the criteria or the value defined for the constant element.
  • greater-than-or-equal - Performs a search for values that are greater than or equal to either the criteria or the value defined for the constant element.
  • less-than-or-equal - Performs a search for values that are less than or equal to either the criteria or the value defined for the constant element.
  • range - Performs a search against a range of either static or user-defined ranges. If you select this option, you must specify upper and lower bounds in a default element.
Tip –
If a field is to be used for simple range searching (where the user or incoming message supplies lower and upper limits of the range are supplied) be sure to define that field for range searching in midm.xml for the searches that use this query. For more complex range searches that use offset values or constants instead of user-supplied limits, do not define the field for range searching in midm.xml.
field
The fully qualified field name of the field to be included in the query block (for example, Enterprise.Person.Address.AddressLine1).
source
The qualified field name of the source field in the object from which the criteria is obtained (for example, Person.Address.AddressLine1). An asterisk (*) can be used as a wildcard character. If the criteria should be a constant value instead of being supplied by a user or incoming message, define a constant element instead of a source element.
Tip –
When a field in a child object is defined for a blocking query, use the asterisk wildcard character in the ePath to the source field to ensure all instances of the child object in an incoming message are used as search criteria. Each instance is joined by an OR operator. For example, this configuration:
<field>Enterprise.SystemSBR.Person.Alias.FirstName
</field>
<source>Person.Alias[*].FirstName</source>
would result in a WHERE clause similar to this:
WHERE Alias.FirstName=”Meg” OR Alias.FirstName=”Maggie”
constant
A constant value that provides the criteria for a search. Define this element instead of a source element if the criteria is a constant rather than being user defined. You can use a constant value with the following types of queries: equals, not-equals, greater-than-or-equals, and less-than-or-equals.
default
A list of upper and lower limits defining a range search. If no limits are defined, the search is a simple range search in which the upper and lower values are supplied by the user or the incoming message (for example, in “Date of Birth From” and “Date of Birth To” fields).
lower-bound
The lower limit of a constant or offset range search. Use a negative number for the lower limit of an offset search. This number is added to the value supplied for the search to determine the lower limit of the range. The value can be numeric, date, or string. See Range Search Processing for more information.
lower-bound/type
The type of range search. Define the type attribute as offset to use an offset value or as constant to define a lower constant.
upper-bound
The upper limit of a constant or offset range search. The value can be numeric, date, or string. See Range Search Processing or more information.
upper-bound/type
The type of range search. Define the type attribute as offset to use an offset value or as constant to define an upper constant.
query.xml Example
Below is a sample illustrating the elements in query.xml.
<QueryBuilderConfig module-name="QueryBuilder" parser-class=
   "com.sun.mdm.index.configurator.impl.querybuilder.QueryBuilderConfiguration">
   <query-builder name="ALPHA-SEARCH"
    class="com.sun.mdm.index.querybuilder.BasicQueryBuilder"
    parser-class="com.sun.mdm.index.configurator.impl.querybuilder.
    KeyValueConfiguration" standardize="true" phoneticize="false">
      <config>
         <option key="UseWildcard" value="true"/>
      </config>
   </query-builder>
   <query-builder name="PHONETIC-SEARCH"
    KeyValueConfiguration" standardize="true" phoneticize="true">
      <config>
         <option key="UseWildcard" value="false"/>
      </config>
   </query-builder>
   <query-builder name="BLOCKER-SEARCH"
    class="com.sun.mdm.index.querybuilder.BlockerQueryBuilder" parser-
    class="com.sun.mdm.index.configurator.impl.blocker.BlockerConfig"
      <config>
         <block-definition number="ID000000">
            <block-rule>
               <equals>
                  <field>Enterprise.SystemSBR.Person.FnamePhonetic
                  </field>
                  <source>Person.FnamePhoneticCode</source>
               </equals>
               <equals>
                  <field>Enterprise.SystemSBR.Person.LnamePhonetic
                  </field>
                  <source>Person.LnamePhoneticCode</source>
               </equals>
            </block-rule>
         </block-definition>
         <block-definition number="ID000001">
            <block-rule>
               <equals>
                  <field>Enterprise.SystemSBR.Person.SSN</field>
                  <source>Person.SSN</source>
               </equals>
            </block-rule>
         </block-definition>
         <block-definition number="ID000002">
            <hint>ALL_ROWS</hint>
            <block-rule>
               <equals>
                  </field>
               </equals>
               <range>
                  <field>Enterprise.SystemSBR.Person.DOB</field>
                  <source>Person.DOB</source>
                  <default>
                     <lower-bound type="offset">-5</lower-bound>
                     <upper-bound type="offset">5</upper-bound>
                  </default>
               </range>
               <equals>
                  <field>Enterprise.SystemSBR.Person.Gender</field>
                  <source>Person.Gender</source>
               </equals>
            </block-rule>
         </block-definition>
      </config>
   </query-builder>
</QueryBuilderConfig>
