Sun Master Index Configuration Reference
validation.xml File Structure
validation.xml consists primarily of a list of rules. Each rule is defined within the ValidationConfig element and is defined by attributes within a rules element. Table 13 describes the elements and attributes of validation.xml.
Table 13 update.xml File Elements
Element or Attribute
Description
rules
The configuration information for the validation rules.
rule
The configuration information for a specific validation rule in a rules list.
rule/name
A rule attribute that specifies a name for the validation rule.
rule/object-name
A rule attribute that specifies the name of the class that defines the object to which the validation rule is applied, such as SystemObject or ParentNameObject (where ParentName is the name of the parent object in the Object Definition).
rule/class
A rule attribute that specifies the complete path of the Java class containing the validation rule.
