Sun Master Index Configuration Reference
Master Index validation.xml File
By default, validation.xml (validation.xml) defines certain validations for the local identifiers assigned by each external system. You can create custom Java classes that define rules for validating field values before they are saved to the master index database. You can then specify the Java classes in validation.xml to make them part of the Sun Master Index application.
