Maintaining Sun Master Indexes
Modifying the Master Index Database
There might be times when you need to modify the master index database. For example, you might need to add or modify a stored procedure or index, or you might need to add new common codes. You must modify the database if you add fields or objects to the object structure in order to reflect the new structure in the database tables. If you make changes to the database, rebuild and redeploy the master index server project to ensure the changes are picked up by the application. The only exception to this is when you add external systems.
