Sun Master Index Configuration Guide
Specifying the Master Index Chunk Size
You can specify a number of EUIDs to be allocated at one time to the EUID generator. This allows the generator to assign EUIDs to multiple records without needing to query the sbyn_seq_table database table each time, which improves performance. For detailed information about the chunk size and how EUIDs are allocated, see Manager Service Components in Sun Master Index Configuration Reference .
ProcedureTo Specify the Chunk Size
  1. In the Projects window, expand the Configuration node in the project you want to modify, and then double-click master.xml.
  2. Scroll to the third parameter element, ChunkSize, in the EuidGeneratorConfig element.
  3. Change the value of the parameter-value element to the desired chunk size.
    For example:
    <parameter>
        <parameter-name>EuidGeneratorConfig</parameter-name>
        <parameter-type>java.lang.Integer</parameter-type>
        <parameter-value>100</parameter-value>
    </parameter>
  4. Save and close the file.
