Sun Master Index Configuration Guide
Defining Master Index Update Policies
You can define update policies for any of the seven update policy elements. You do not need to specify a policy for each element.
ProcedureTo Define Update Policies
  1. In the Projects window, expand the Configuration node in the project you want to modify, and then double-click update.xml.
    The file opens in the NetBeans XML editor.
  2. Scroll to the UpdateManagerConfig section of the file.
  3. Do any of the following:
    • To modify the merge policy for enterprise objects, change the value of the EnterpriseMergePolicy element to the fully qualified name of the new Java class.
      For example:
         <EnterpriseMergePolicy>com.sun.mdm.index.user.MyEntMergePolicy
         </EnterpriseMergePolicy>
    • To modify the unmerge policy for enterprise objects, change the value of the EnterpriseUnmergePolicy element to the fully qualified name of the new Java class.
      For example:
         <EnterpriseUnmergePolicy>com.sun.mdm.index.user.MyEntUnmergePolicy
         </EnterpriseUnmergePolicy>
    • To modify the update policy for enterprise objects, change the value of the EnterpriseUpdatePolicy element to the fully qualified name of the new Java class.
      For example:
         <EnterpriseUpdatePolicy>com.sun.mdm.index.user.MyEntUpdatePolicy
         </EnterpriseUpdatePolicy>
    • To modify the create policy for enterprise objects, change the value of the EnterpriseCreatePolicy element to the fully qualified name of the new Java class.
      For example:
         <EnterpriseCreatePolicy>com.sun.mdm.index.user.MyCreatePolicy
         </EnterpriseCreatePolicy>
    • To modify the merge policy for system objects, change the value of the SystemMergePolicy element to the fully qualified name of the new merge policy Java class.
      For example:
         <SystemMergePolicy>com.sun.mdm.index.user.MySysMergePolicy
         </SystemMergePolicy>
    • To modify the unmerge policy for system objects, change the value of the SystemUnmergePolicy element to the fully qualified name of the new Java class.
      For example:
         <SystemUnmergePolicy>com.sun.mdm.index.user.MySysUnmergePolicy
         </SystemUnmergePolicy>
    • To modify the assumed match policy, change the value of the UndoAssumeMatchPolicy element to the fully qualified name of the new Java class.
      For example:
      <UndoAssumeMatchPolicy>com.sun.mdm.index.user.MyUndoAsmMatchPolicy
         </UndoAssumeMatchPolicy>
  4. Save and close the file.
