Sun Master Index Configuration Guide
Defining MIDM Local ID Labels
The local-id element, which is nested in the gui-definition element, defines alternate names for the local ID headings and labels. The name defined here replaces the default local ID heading and field names on all pages, including the search result column names. This element is optional, and if it does not exist the label names default to “Local ID”.
ProcedureTo Define Local ID Labels
  1. In the Projects window, expand the Configuration node in the project you want to modify, and then double-click midm.xml.
    The file opens in the NetBeans XML editor.
  2. Scroll to the local-id element in the gui-definition element.
  3. Enter the name you want to appear on the MIDM for the local ID fields and headings.
  4. Save and close the file.
