Sun Master Index Configuration Guide
Specifying the Master Controller JNDI Class
The MIDM must know the name of the Master Controller interface for the Sun Master Index implementation. Only change this value if you create a custom Master Controller.
ProcedureTo Specify the Master Controller JNDI Class
  1. In the Projects window, expand the Configuration node in the project you want to modify, and then double-click midm.xml.
    The file opens in the NetBeans XML editor.
  2. Scroll to the impl-details element, and then to the master-controller-jndi-name element.
  3. Modify the value of the master-controller-jndi-name element to the name of the Master Controller JNDI class for your server.
    For example:
    <master-controller-jndi-name>ejb/CustomerMasterController
    </master-controller-jndi-name>
  4. Save and close the file.
