By default, the length of the EUIDs generated by the master index application is 10 characters. You can modify this value if needed. You can also specify a new starting EUID number. This is described in Creating the Master Index Database in Sun Master Index User’s Guide.
If you increase the length of the EUIDs to longer than 20 characters or if the EUID length plus the checksum length is longer than 20 characters, you need to increase the length of the EUID columns in the script that creates the database tables.
In the Projects window, expand the Configuration node in the project you want to modify, and then double-click master.xml.
Scroll to the first parameter element, IdLength, in the EuidGeneratorConfig element.
Change the value of the parameter-value element to the desired length of the EUID.
For example:
<parameter> <parameter-name>IdLength</parameter-name> <parameter-type>java.lang.Integer</parameter-type> <parameter-value>12</parameter-value> </parameter> |
Save and close the file.
