Sun Master Index Configuration Guide
Deleting a Custom Comparison Function
If you add a custom comparison function to a master index application in error, you can remove it from the Match Engine node. Optionally, you can simply make the comparison function unavailable by removing it from the comparators list in comparatorsList.xml.
ProcedureTo Delete a Custom Comparison Function
  1. Back up the source files for the function in case you need them at a later time.
  2. In the Project window, navigate to the Match Engine node in the master index project and then to the /lib folder.
  3. Right-click the folder containing the files to remove, and then select Delete.
    A confirmation dialog appears.
  4. Click Yes.
    The source files are removed from the project.
  5. Open comparatorsList.xml and remove the comparator definitions from the list.
  6. Save and close the file.
