Sun Master Index Configuration Guide
Configuring Master Index Merged Record Updates
The merged-record-update element allows you to define whether updates can be made to records with a status of Merged.
ProcedureTo Allow Merged Record Updates
  1. In the Projects window, expand the Configuration node in the project you want to modify, and then double-click master.xml.
  2. In the MasterControllerConfig element, change the value of the merged-record-update element to Enabled.
    For example:
    <merged-record-update>Enabled</merged-record-update>
  3. Save and close the file.
ProcedureTo Prevent Merged Record Updates
  2. In the MasterControllerConfig element, change the value of the merged-record-update element to Disabled.
    For example:
    <merged-record-update>Disabled</merged-record-update>
