Sun Master Index Configuration Guide
Setting Master Index Blocking Query Options
Key and value pairs are designed to fine-tune the operation of custom blocking queries. In the default blocking queries defined in query.xml, key and value pairs are not used. However, if you create a custom blocking query, you can configure the query to use key and value pairs. The key describes the option, and the value specifies the value of the option.
ProcedureTo Set Blocking Query Options
  1. In the Projects window, expand the Configuration node in the project you want to modify, and then double-click master.xml.
  2. Scroll to the execute-match element.
  3. To specify a key and value pair, modify the values of the key and value attributes in the option element.
    For example:
    <option key="wildcard" value="true"/>
  4. To delete a key and value pair, remove the option element.
  5. Save and close the file.
