Master
Index Variants Properties
The following table lists and describes the Configuration Editor
fields and XML elements that define a variant for normalization or
standardization. In the XML file, each value and locale pair are defined
within a locale_codes element. A list of locale_codes elements can be defined in the locale_maps element.
Configuration Editor Field
XML File Element or Attribute
Description
Value
value
A value that indicates to the standardization engine which variant to
use to standardize the data. When the value is contained in the Variant
Field Name field (or the locale-field-name element),
the standardization engine uses the corresponding Variant field (or
locale element) to determine the variant. To specify a default variant,
enter “Default”.
Variant
locale
A code indicating which variant to use to standardize data
when the identifying field value in a transaction matches the corresponding
Value field or element. Select one of the following codes.
AU - Australia
FR - France
UK - United Kingdom
US - United States
