Sun Master Index Configuration Guide
Master Index Phonetic Encoding Fields and Elements
The following table lists and describes the Configuration Editor fields and XML file elements used to define how fields will be phonetically encoded.
Configuration Editor Field
XML File Element
Description
Unphoneticized Source
unphoneticized-source- field-name
The ePath of the source field in the system object that contains the data to be phonetically encoded (for example, Person.Address[*].StreetName).
Note –
This can refer to the original field or to a standardized or normalized field.
Phoneticized Target
phoneticized-target- field-name
The ePath of the field in the system object that will store the phonetically encoded value of the source field.
phoneticized-object- field-id
A field ID to identify the field to the phonetic encoder. This is not currently used with the Master Index Standardization Engine, but could be used with a custom standardization engine.
Encoder
encoding-type
The phonetic encoder to use for this field. This must correspond to an encoder defined in the Encoders section on the Configuration Editor (or the PhoneticEncodersConfig element of the XML file).
