Field
field
The name of the field to be included in the query block. On
the Configuration Editor, you can click Browse to select a field or
enter the fully qualified field name manually.
Source
source
The name of the source field in the object from which the criteria
is obtained. Click Browse to select a field, or enter the qualified
field name manually. An asterisk (*) can be used as a wildcard character.
Tip –
When a field in a child object is defined for a blocking
query, use the asterisk wildcard character in the ePath to the source
field to ensure all instances of the child object in an incoming message
are used as search criteria. Each instance is joined by an OR operator.
For example, this configuration:
<field>Enterprise.SystemSBR.Person.Name.FirstName
</field>
<source>Person.Name[*].FirstName</source>
would result in a WHERE clause similar to this:
WHERE Name.FirstName=”Meg” OR Name.FirstName=”Maggie”
Operator
type of search
An indicator of the type of search to perform on the field.
On the Configuration Editor, you can select one of the following values
from the drop-down list. In the XML file, you specify one of the following
names for the XML element that defines one field in a query block.
equals - Performs an exact search against either the criteria
or the value defined for the “Use Constants” option.
not-equals - Searches
for values that do not equal either the criteria or the value defined
greater-than-or-equal -
Performs a search for values that are greater than or equal to either
the criteria or the value defined for the “Use Constants”
option.
less-than-or-equal -
Performs a search for values that are less than or equal to either
option.
range - Performs a search against a range
of either static or user-defined ranges. If you select this option,
you must specify upper and lower bounds.
Tip –
If a field is to be used for simple range searching (where
the user or incoming message supplies lower and upper limits of the
range are supplied) be sure to define that field for range searching
in midm.xml for the searches that use this query. For more complex range
searches that use offset values or constants instead of user-supplied
limits, do not define the field for range searching in midm.xml.
Use Constant/Value
constant
On the Configuration Editor, this is an indicator of whether
to use a constant value as the search criteria for the field. When
this option is selected, you need to enter the constant in the corresponding
Value field. In the XML file, enter the value of the constant in the constant element.
Upper
Bound Type
upper-bound/type
For range searching only, the type of value to use for the upper
limit of the search range. Select or enter one of the following options.
not defined - No specific upper limit is
defined; a user enters the value when performing the search. Be sure
to define this field for range searching in the MIDM as well.
In the XML file, this is indicated by omitting the upper-bound element.
constant - A specific value is defined to
use as the upper limit of the range when no search criteria is entered
or when incomplete information is available.
offset - A value to be added to the user-supplied
value to determine the upper limit on the search range.
For
constant and offset, enter the value in the corresponding Value field.
Lower
Bound Type
lower-bound/type
For range searching only, the type of value to use for the lower
limit of the search range. Select one of the options listed for Upper
Bound Type. If you select offset, the value you specify for the offset
will be subtracted from the user-supplied value.
Value (for the
upper and lower bounds)
upper-bound
lower-bound
For constant and offset range searching, the upper or lower
limit of the range. For constants, this is the upper or lower limit;
for offsets, this is the value added to or subtracted from the user-supplied
value. It can be numeric, date, or string. In the XML file, the upper-bound and lower-bound elements
fall within an element named default.
