An indicator of whether wildcard characters are allowed when
executing this search. This parameter is available for basic queries
only. On the Configuration Editor, select this check box if wildcard
characters are allowed in any of the search fields.
In the XML file, each option element configures
one parameter for the query and contains a key and value pair. The key attribute names the
parameter. For the default basic query, the name is UseWildCard. The value attribute
specifies the value of the corresponding key attribute.
For the UseWildCard parameter, specify true to allow wildcard characters for that query type; otherwise
specify false.
When wildcard characters are enabled, you can enter a percent
sign (%) into search criteria to represent multiple unknown characters.
Note –
If you define a custom query, you can use key and value
options to define any required parameters.
