description
This is an optional element that briefly describes the parameter.
Note that there are no parameters to define for the UnionSurvivorStrategy.
parameter-name
The name of the parameter.
For the DefaultSurvivorStrategy, this value is “preferredSystem”.
For the WeightedSurvivorStrategy, this value is “ConfigurationModuleName”.
For the UnionSurvivorStrategy, this is not used.
parameter-type
The Java data type for the parameter value. For both the DefaultSurvivorStrategy
and the WeightedSurvivorStrategy, this value is java.lang.String.
parameter-value
The value of the named parameter.
For the DefaultSurvivorStrategy, this is the processing
code of the source system from which the SBR field value is retrieved.
For the WeightedSurvivorStrategy, this is the name
of the module-name element that defines the weighted
calculator to use as the default strategy (by default, WeightedSurvivorCalculator).
