Sun Master Index Configuration Guide
Master Index Weighted Calculator Parameter Elements
The following table lists and describes the elements that configure the parameters for the weighted calculator in update.xml.
Element
Description
quality
The type of weighted calculation to perform, such as:
preference
The preferred value for the specified quality. This element is only used for the SourceSystem quality and the preference must be a source system code.
utility
A value that indicates the reliability of the specified quality for determining the best field value for the SBR. You define the scale for the utility values.
