Sun Master Index User's Guide
Standardization Engine Plug-ins
You can define classes to connect to a custom standardization engine instead of the Master Index Standardization Engine. Specify the names of the custom classes you create in the standardizer-api and standardizer-config elements of mefa.xml. Follow these guidelines when implementing custom standardization engine classes.
You can also define custom standardization rules to plug in to the Master Index Standardization Engine. For more information, see Master Index Standardization Engine Reference.
