Sun Master Index User's Guide
Step 3: Define Master Index Database Indexes
To optimize data processing in the master index application, you can define additional indexes for the database tables that store object data. Best practice is to define indexes for each field used for searching, blocking, or matching. You can define these indexes in create.sql or create a new script. Before you begin this step, complete Step 2: Create a Master Index Database and User.
ProcedureTo Define an Index
  1. Do one of the following:
    • Under the master index project in the Projects window, expand Database Scripts and then open create.sql in the NetBeans editor.
    • On your computer, navigate to project_home/src/DatabaseScript, where project_home is the location of the master index project files. Open create.sql in a text editor.
  2. Do any of the following:
    • Remove an existing index definition (not recommended).
    • Create new index definitions for the required fields.
    • Modify an existing index definition.
  3. Save and close the file.
  4. Continue to Step 4: Define Master Index External Systems.
