Scheduler Binding Component User's Guide
Monitoring a Scheduler Binding Component Project
You can monitor your deployed Scheduler project from the GlassFish Admin Console.
The Admin Console monitors the following statistics for your component:
ProcedureOpen the Admin Console Monitoring Window
  1. From the NetBeans Services window, right-click GlassFish V2 under Servers and choose View Admin Console from the pop-up menu. You can also access the Admin Console at http://localhost:4848/login.jsf.
  2. In the Admin Console's Common Tasks tree, select sun-scheduler-binding under JBI -> Components.
  3. Select the Monitoring tab.
    Image shows the Admin Console Monitoring Window as described
in context
  4. To see the latest statistics, refresh your screen regularly.
