Getting Started with the Java Dynamic Management Kit 5.0
Querying and Filtering
Querying and filtering are performed by the MBean server itself, not by a separate MBean. This ensures that such critical services are always available. Queries and filters are performed in a single operation, whose goal is to select for the purpose of selecting the MBeans on which management operations are performed.
Usually, a management application performs a query to find the MBeans that will be the target of its management requests. To select MBeans, applications can specify:
For example, a filter could select all the MBeans whose object names contain MyMBeans and for which the attribute named color is currently equal to red.
The result of a query operation is a list of MBean object names, which can then be used in other management requests.
