Getting Started with the Java Dynamic Management Kit 5.0
SNMPv1 and SNMPv2 Access Control
SNMPv1 and v2 define an access control mechanism similar to password authentication. Lists of authorized manager host names are defined in an access control list (ACL) stored in a file on the agent side, called the IP ACL file. There are no passwords, but logical community names (IP addresses) can be associated with authorized managers to define sets of allowed operations.
The SNMP adaptor performs access control if an ACL file is defined. Because SNMP is a connection—free protocol, the manager host and community are verified with every incoming request. By default, the file is not loaded and any SNMP manager can send requests.
The ACL file is the default access control mechanism in the SNMP protocol adaptor. However, you can replace this default implementation with your own mechanism. For example, if your agent runs on a device with no file system, you could implement access control lists through a simple Java class.
