Name | Synopsis | Description | Options | Examples | Exit Status | See Also
enable-monitoring [--help]
[--mbean={false|true}]
[--dtrace={true|false]
[--modules modules[=level][:module[=level]]*
[--pid pid]
[--options options={true|false]]
The enable-monitoring subcommand is used to turn on monitoring for Enterprise Server or for particular modules during runtime. Changes are dynamic, that is, server restart is not required.
By default, the monitoring service is enabled, that is, the monitoring-enabled attribute of the monitoring-service element is true. However, the default monitoring level for individual modules is OFF. This subcommand used with the --modules option can enable monitoring for a given module by setting the monitoring level to HIGH or LOW. If level is not specified when running the subcommand, the level defaults to HIGH.
The specific meanings of HIGH or LOW are determined by the individual containers. For a list of monitorable modules, see the --modules option in this help page.
An alternative method for enabling monitoring is to use the set subcommand. In this case, the server must be restarted for changes to take effect.
This subcommand is supported in remote mode only.
Displays the help text for the subcommand.
Enables Mbean monitoring. Default value is false.
Only usable if the DTrace Monitoring module is present. Enables Solaris DTrace monitoring. Default value is false.
Enables specified module or modules by indicating monitoring level. Valid levels are OFF, HIGH, LOW. If level is not specified, the default setting is HIGH. Multiple modules are separated by : (colon). Monitorable modules include connector-connection-pool, connector-service, ejb-container, http-service, jdbc-connection-pool, jersey, jpa, jms-service, jvm, security, thread-pool, transaction-service, web-container, jruby-container, and web-services-container. Additional modules can be listed by using the get subcommand.
To set the level of JRuby container monitoring you need to deploy at least one Ruby application or use the configure-jruby-container subcommand to enable monitoring. For more information, see configure-jruby-container(1).
Specifies the Enterprise Server JVM process identifier (PID). When monitoring is enabled, the btrace-agent is attached, based on the specified PID. Need to specify only in exceptional cases when the system cannot determine the PID. In this situation, the subcommand prompts for the PID of the corresponding Enterprise Serverprocess.
Sets the following btrace-agent options:
Enables debugging for BTrace. Default value is false.
This example enables monitoring for Enterprise Server in general by setting the enable-monitoring flag to true (default is true).
asadmin> enable-monitoring Command enable-monitoring executed successfully |
This example enables monitoring for specific containers by setting their monitoring levels.
asadmin> enable-monitoring --modules web-container=LOW:ejb-container=HIGH Command enable-monitoring executed successfully |
This example turns on debugging.
asadmin> enable-monitoring --options debug=true Command enable-monitoring executed successfully |
