Table E–1 shows the various AccessX features and their associated keystrokes. You must start OpenWindows with the -accessx option to use these keystrokes.
Table E–1 Features and Their Keystrokes
Feature |
Keystroke |
Turn StickyKeys on or off. |
Press Shift five times. |
Turn StickyKeys off. |
Press any two modifiers (e.g., Shift and Alt) at once. Note: You must turn this ability on from the Settings menu. |
Turn MouseKeys on or off. |
Alt - Shift - Num Lock |
Move the pointer (when MouseKeys is turned on). |
1-4, 6-9 keys on the numeric keypad |
Click Double-click Press Release |
5 0 . + |
SELECT (mb1) ADJUST (mb2) MENU (mb3) |
Turn RepeatKeys on or off. |
Hold down Shift for eight seconds (beeps at four seconds) |
Turn SlowKeys on or off. |
