Manual reference pages, traditionally known as “man pages,” can be displayed using the Man Page Viewer action. The action icon is located in the Desktop_Apps folder in Application Manager.
Click the Application Manager control in the Applications subpanel of the Front Panel.
Application Manager opens.
Double-click the Desktop_Apps icon.
Double-click the Man Page Viewer icon.
A dialog box is displayed, prompting you to enter a man page name.
Type the name of the man page you want to see and optional command line options, and press Return.
The man page is displayed in a quick help window.
Click Close to dismiss the man page.
For a list of command line options available with the man command, display the man(1) man page.
