There are several ways to start Image Viewer:
From the Workspace Programs menu
From Application Manager
From the command line
Place the mouse pointer anywhere on the background of the desktop (the workspace) and click mouse button 3.
The Workspace menu appears.
Choose Programs, and then choose Image Viewer from the Programs submenu.
Open Application Manager by clicking the Applications icon on the Applications subpanel of the Front Panel.
Double-click Desktop_Apps in the Application Manager window.
The Desktop_Apps group is displayed in Application Manager.
Double-click Image Viewer in the Desktop_Apps group.
Image Viewer opens.
Install Image Viewer in the Front Panel.
Image Viewer has new features which can be accessed by running the tool from the command line. To start Image Viewer and open files directly from the command line:
Or, type sdtimage filename to start Image Viewer and open a specific file.
Choose Exit from the File menu.
