This section describes how to do window-related activities through your keyboard.
From the Front Panel:
Press Alt+Tab to move the keyboard focus to the Front Panel.
Press the arrow keys to move the highlight within the Front Panel and select a control.
Press Return or the Spacebar to choose the control and open the application's window.
From Application Manager:
Open the Application Manager window by choosing its Front Panel control as described above.
Press the arrow keys to move the highlight to an application group icon within the Application Manager window.
Press Return twice to open the application group.
Press the arrow keys to move the highlight to an application or action icon, then press Return twice to start the application.
From a terminal emulator window:
Open a terminal emulator window by choosing its Front Panel control as described above.
When the window opens, type the command that starts the application.
Closing a window removes it from all workspaces.
Before closing an application window, save your work.
Press Alt+Tab to move the highlight to the window or icon you want to select.
When a window or icon is selected, its border changes color to show that it is active and will receive input from the mouse or keyboard.
Press Alt+Tab to move the highlight to the window you want to minimize.
Press Alt+Spacebar to display the Window menu.
Choose the Minimize item:
Press Down Arrow until you select Minimize, then press Return.
Or, press N, the menu's mnemonic for Minimize.
Press Alt+Tab to move the highlight to the icon you want to restore.
Press Down Arrow to choose Restore, then press Return.
Press Alt+Tab to move the highlight to the window or icon you want to move.
Press M, the menu's mnemonic for Move.
Press the arrow keys to relocate the window or icon.
Hold down Control while you press an arrow key to speed up the movement of the window or icon.
When you've moved the window or icon where you want it, press Return.
To cancel the move operation, press Esc.
Press Alt+Tab to move the highlight to the window you want to resize.
Press S, the menu's mnemonic for Size.
Press the arrow keys to stretch or shrink the window. An outline appears to show you the window's size.
Hold down Control while you press an arrow key to size the window faster.
When the outline shows the size you want, press Return.
To cancel the resize operation, press Esc.
Press Alt+Tab to move the keyboard focus, as shown by the highlight, to the window whose contents you want to scroll.
Press Tab to move to the window area you want to scroll.
Press the arrow keys, Prev and Next, or Page Up and Page Down.
Hold down Control while you press an arrow key to scroll faster.
Some windows and dialog boxes display lists from which you select options or settings.
Press Tab to move the highlight to the list.
Press the arrow keys to move through the list.
To select more then one contiguous item in lists that allow you to do so, press Shift+Down Arrow or Shift+Up Arrow.
Press Tab to move the highlight to the appropriate button (such as OK), then press Return.
To display a pull-down menu from a window's menu bar:
Press Alt+Tab to move the highlight to the application window.
Press F10 to move the highlight to the name of the first menu in the menu bar, then use the arrow keys to display menus and move among their items.
Press Return to choose a highlighted item.
To dismiss a menu without choosing an item, press Esc.
With the keyboard focus on the component whose pop-up menu you want to display:
Press Shift+F10 to display the pop-up menu.
Choose a menu item:
Press the Down Arrow key to move through the menu, highlight the item you want, then press Return.
Or, type the underlined letter in the menu item's name (its mnemonic).
Or, type the shortcut key, as listed to the right of the item's name.
Press Alt+Tab or Alt+Esc to move the keyboard focus, as shown by the highlight, to the window or icon.
Press the key for the menu item's mnemonic (the underlined character in the item's name).
To close the menu without choosing an item, press Esc.
Press Alt+Tab until you've placed the keyboard focus, as shown by the highlight, on the Front Panel.
Press the arrow keys to move the highlight to the button for the workspace you want to display.
Press Return or the Spacebar.
Press the arrow keys to move the highlight to the button for the workspace you want to rename.
Press Shift+F10 to display the workspace button's pop-up menu.
Press the Down Arrow key to select Rename, then press Return.
The button becomes a text field.
Edit the workspace's name in the text field.
Once you've renamed the workspace, press Return.
To move to the next window or icon, press Alt+Tab or Alt+Esc.
To move to the previous window or icon, press Shift+Alt+Tab or Shift+Alt+Esc.
To shuffle through a stack of windows, press Alt+Up Arrow or Alt+Down Arrow.
To move between the windows belonging to an application, or the Front Panel and a subpanel, press Alt+F6 or Shift+Alt+F6.
Press Alt+Tab to move the keyboard focus, as shown by the highlight, to the window you want to display in other workspaces.
Display the Window menu by pressing Alt+Spacebar.
Press the Down Arrow key to select Occupy Workspace, then press Return.
The Occupy Workspace dialog box appears.
Press Tab until the keyboard focus is in the Workspaces list.
Select the workspaces in which you want the window to appear:
Press Down Arrow or Up Arrow to move through the list.
To select more than one workspace, press Shift+Down Arrow or Shift+Up Arrow.
Press Tab to move the keyboard focus to OK, then press Return or the Spacebar.
Press the arrow keys to move the highlight within the Front Panel to one of the subpanel arrow controls, then press Return.
Press the arrow keys to move the highlight among the controls within the subpanel, then press Return or the Spacebar to choose a selected control.
To close the subpanel without choosing a control, press Esc.
Press Alt+Spacebar to display the Front Panel menu.
Press the arrow keys to relocate the Front Panel.
Hold down Control while you press an arrow key to speed up the movement of the Front Panel.
When you've moved the Front Panel to where you want it, press Return.
