Solaris Common Desktop Environment: User's Guide
Accessing PDA Sync Software
Access the PDA Sync software using the following procedure.
  1. Using the desktop icon, open the Applications pull-down menu from the Front Panel (typically at the bottom of your screen), click on Applications to open Application Manager.
  2. Double-click on Desktop_Apps to locate the PDA Sync icon.
  3. Click on the PDA Sync icon.
    You can also access the PDA software by entering /usr/dt/bin/sdtpdasync an the command line.
    In order to make the PDA Sync icon more accessible in the future, drag and drop the PDA Sync icon from the Desktop_Apps screen into the Install area of the Application pull-down menu or into your user space.
    For more information on the PDA Sync application, see the Help information on the PDA Sync software.
