The Configure Calendar Conduit window enables you to determine how appointments are synchronized between calendar applications. Refer to the following figure.
In this window you can:
Change the host name. The default is user@host.
Specify the base calendar on the workstation or server.
Determine a rolling date range to synchronize. The default range is six months.
Determine what information is displayed for others to see on private appointments marked on your PDA.
Change the data synchronization direction to:
Synchronize the files (this is the default) — merges the calendar information on your desktop and your PDA.
Desktop overwrites PDA — replaces your PDA calendar information with the calendar information you have on your workstation.
PDA overwrites desktop — replaces your desktop calendar information with the calendar information you have on your PDA.
