To open the Removable Media Manager:
In File Manager, choose Removable Media Manager from the File menu.
From the Front Panel, click the Removable Media Manager icon in the Files subpanel.
From the Workspace menu, choose Removable Media Manager in the Folders menu.
When Removable Media Manager starts, it displays all media currently loaded into the drives. The different forms of devices are represented by icons and are unlimited. For example, if a machine has three drives loaded with diskettes, three diskette icons are displayed. The icon view updates each time a device is inserted or ejected. Each class of media is represented by a different icon.
You can select one or more devices and perform operations on them. A device is displayed with a nickname (cdrom0), an optional volume name (ssa_2_1_sparc), and an optional partition or slice number (s1).
In order to have the Removable Media Manager recognize a diskette, you must choose Open Floppy from one of the following:
File subpanel of the Front Panel
File menu of the File Manager
Folders menu of the Workspace Menu
