You can search for a word or phrase in your document. The Find command begins from the position of the insertion cursor and proceeds through the entire document. You can automatically replace or delete occurrences found in your document.
Searches are case sensitive. To find all occurrences, search for both lowercase and uppercase instances.
Choose Find/Change from the Edit menu or press Control+F.
Type the text you want to find in the Find field.
Press Return or click the Find button to locate the next occurrence of the text.
To find additional occurrences, press Return or click Find again.
Type the replacement text in the Change To field.
Click Change to replace a single occurrence.
To find and change additional occurrences, click Find and then Change.
Or, click Change All to replace all occurrences.
There is no Undo for Change All.
Click Close when you are done.
Type the text you want to delete in the Find field.
Leave the Change To field blank.
Press Return or click Find to locate the next occurrence.
Click Change to delete a single occurrence.
