Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Configuring Database, Icon, and Help Services
Usually, the action and data type definitions, icons, and help data files associated with an application are installed onto the same system as the application.
For example, consider the typical configuration of help data files:
To Create a Database, Help, or Icon Server
  1. Provide the operating system network configurations required by the desktop.
    See Configuring Base Operating System Networking for the Desktop.
  2. Provide the general desktop configuration required for clients.
    See To Configure Desktop Clients and Servers.
  3. Install the database, help, or icon files.
    The files can be located anywhere on the system. However, it may be easier to use the following locations, since these are the directories automatically searched when a system has been designated an application server.
    • Database files: /etc/dt/appconfig/types/language
    • Help files: /etc/dt/appconfig/help/language
    • Icon files: /etc/dt/appconfig/icons/language
      If you are setting up a database server, the actions must be written to specify where their commands (EXEC_STRINGs) will run. See Specifying a Remote Execution Host.
To Configure the Session Server to Find a Database, Icon, or Help Server
  3. Add the database, icon, or help server to the appropriate search path.
    • If you placed the data files in other locations, you must modify the specific search path.
      For example, if you placed the help files in directory /etc/dt/help on system SysCCC, you would add the following line to /etc/dt/config/Xsession.d/0010.dtpaths:
      		export DTSPSYSHELP=/net/SysCCC/etc/dt/help
      For more information about setting search paths, see:
