Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Specifying a Different Default Terminal Emulator
The default terminal emulator used by actions is dtterm. You can change this to another terminal emulator. The default terminal emulator is used when the action does not explicitly specify a terminal emulator to use.
The terminal emulator used by actions must have these command-line options:
