Create a file in the appropriate language-dependent directory (for example, in /etc/dt/appconfig/types/japanese) .
Copy the action definition to the language-dependent configuration file.
For example, you might copy an action definition from
app_root/dt/appconfig/types/C/file.dt
to
app_root/dt/appconfig/types/japanese/newfile.dt
Add a LABEL field or modify the existing LABEL field.
LABEL string
Application Manager and File Manager use the label string to identify the action's icon.
Localize any of the following fields in the action definition:
For localized icons: ICON
For localized On Item help: DESCRIPTION
For localized prompts: any quoted text in the EXEC_STRING
