This section describes how to create a data type configuration file.
The requirements for configuration files containing data type definitions are:
The files must use the naming convention name.dt
The files must be located on the database search path. The default search path is:
Personal data types—HomeDirectory/.dt/types
System-wide data types—/etc/dt/appconfig/types/language
Built-in data types—/usr/dt/appconfig/types/language. You should not use this directory.
For information on modifying the database search path, see Setting the Value of a Search Path.
Open an existing database file or create a new one.
For more information, see the previous section, Configuration Files for Data Types.
Define the data attributes for the data type using the syntax:
DATA_ATTRIBUTES data_type_name
ICON image_name
DESCRIPTION string
attribute_field
attribute_field
where:
data_type_name—a unique name given to this data type.
image_name—file name or path of an icon file. Use the base name for the file. For example, for icon files myimage.m.pm and myimage.t.pm, use myimage.
attribute_field—field that defines the appearance or behavior of the data type.
string—character string. The contents will be the on-item help for the data type.
Define the data criteria for the data type using the syntax:
DATA_CRITERIA criteria_name
DATA_ATTRIBUTES_NAME data_type_name
criteria_field
criteria_field
where:
criteria_name—unique name for this criteria definition
data_type_name—name used in the DATA_ATTRIBUTES definition
criteria_field—field used to define the criteria for assigning a file to this data type
Save the database file.
Create the icons for the data type.
For more information, see Specifying the Icon Image Used for a Data Type.
If necessary, create the actions listed in the ACTIONS field of the attributes definition.
Double-click Reload Actions in the Desktop_Tools application group to reload the database.
Suppose your system contains an application named xgif, which displays GIF pictures. Ordinarily, you run the program by executing:
xgif filename
You want to be able to display GIF pictures several ways:
By double-clicking a GIF data file
By selecting the data file and choosing the application from the Selected menu
Open a new file HomeDirectory/.dt/types/GifViewer.dt for editing.
Type the data type definitions:
DATA_ATTRIBUTES Gif
DESCRIPTION Gif image file.
ICON GifIcon
ACTIONS View
DATA_CRITERIA Gif_Criteria
DATA_ATTRIBUTES_NAME Gif
Type the action definition for the GifViewer action:
ACTION GifViewer
EXEC_STRING xgif %(File)Arg_1"Gif file to view:"
WINDOW_TYPE NO_STDIO
DESCRIPTION Double-click or drop a file to \
start the Gif viewer.
Since the definition does not include an ICON field, the action will use the system's default icon.
Type the following map action to connect the GifViewer action to the View action listed in the data type definition. Use the ARG_TYPE field to restrict this view action to Gif-type files.
ACTION View
ARG_TYPE Gif
TYPE MAP
MAP_ACTION GifViewer
Save the file.
Double-click Reload Actions in the Desktop_Tools application group to reread the database.
