Use the NAME_PATTERN field to specify the naming requirement. The field value can include the following wildcards:
?—matches any single character
*—matches any sequence of characters (including a null string)
[cc…]—matches any of the characters (c) enclosed in brackets
[c–c]—matches any of the characters in the range c through c
The following data type definition creates a data type based on the file name. The file name must begin with QS and end with .doc.
DATA_ATTRIBUTES QS_Doc
DESCRIPTION This file contains a document for the QS \
project.
ICON Word_Doc
ACTIONS Open
DATA_CRITERIA QS_Doc_Criteria
NAME_PATTERN QS*.doc
DATA_ATTRIBUTES_NAME QS_Doc
The following definition creates a data type for directories named Demo_n where n is 0 through 9.
DATA_ATTRIBUTES Demo_directory
DESCRIPTION This is a directory. Double-click to open it.
ICON Demo
ACTIONS OpenInPlace,OpenNewView
DATA_CRITERIA Demo_directory_criteria
NAME_PATTERN Demo_[0-9]
MODE d
DATA_ATTRIBUTES_NAME Demo_directory
