The following mode fields restrict the data type as described:
f&!w—read-only files
!w—read-only files and directories
f&x—executable files
f&r&x—files that are both writable and executable
x|!w—files that are executable or read-only
The following data type definition creates an data type for read-only, non-executable files whose file names follow the naming convention *.doc. It assumes that a View action has been defined for the data type.
DATA_ATTRIBUTES ReadOnlyDocument { ICON read_only DESCRIPTION This document is not writable. Double- \ clicking runs your editor with a \ read-only copy of the file. ACTIONS View } DATA_CRITERIA ReadOnlyDocument_Criteria { NAME_PATTERN *.doc MODE !d&!x&!w DATA_ATTRIBUTES_NAME ReadOnlyDocument }
